{"name":"magazin Mehatronika","description":"magazin Mehatronika","url":"https:\/\/magazinmehatronika.com","home":"https:\/\/magazinmehatronika.com","gmt_offset":2,"timezone_string":"Europe\/Belgrade","page_for_posts":0,"page_on_front":28753,"show_on_front":"page","namespaces":["frm-admin\/v1","oembed\/1.0","code-snippets\/v1","wp\/v2","wp-sync\/v1","wp-block-editor\/v1","omgf\/v1","litespeed\/v1","litespeed\/v3","wpchill\/v1","modula-best-grid-gallery\/v1","performance-lab\/v1","yoast\/v1","elementor-one\/v1","pll\/v1","complianz\/v1","modula-ai-image-descriptor\/v1","newsletter","ea11y\/v1","elementor\/v1\/documents","elementor\/v1","elementor-ai\/v1","elementor\/v1\/feedback","regenerate-thumbnails\/v1","wp-site-health\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/magazinmehatronika.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/batch\/v1"}]}},"\/frm-admin\/v1":{"namespace":"frm-admin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"frm-admin\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/frm-admin\/v1"}]}},"\/frm-admin\/v1\/install":{"namespace":"frm-admin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/frm-admin\/v1\/install"}]}},"\/frm-admin\/v1\/install-addon":{"namespace":"frm-admin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/frm-admin\/v1\/install-addon"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL izvora za koji se dobavlja oEmbed podatak.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL izvora za koji se dobavlja oEmbed podatak.","type":"string","format":"uri","required":true},"format":{"description":"oEmbed oblik koji se koristi.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Najve\u0107a \u0161irina ugne\u017e\u0111enog okvira u piskelima.","type":"integer","default":600,"required":false},"maxheight":{"description":"Najve\u0107a visina ugne\u017e\u0111enog okvira u piskelima.","type":"integer","required":false},"discover":{"description":"Da li da se obavlja oEmbed zahtev otkri\u0107a za neodobrene dostavlja\u010de.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/oembed\/1.0\/proxy"}]}},"\/code-snippets\/v1":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"code-snippets\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1"}]}},"\/code-snippets\/v1\/snippets":{"namespace":"code-snippets\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false}}},{"methods":["POST"],"args":{"name":{"description":"Descriptive title for the snippet.","type":"string","required":false},"desc":{"description":"Descriptive text associated with snippet.","type":"string","required":false},"code":{"description":"Executable snippet code.","type":"string","required":false},"tags":{"description":"List of tag categories the snippet belongs to.","type":"array","items":{"type":"string"},"required":false},"scope":{"description":"Context in which the snippet is executable.","type":"string","required":false},"condition_id":{"description":"Identifier of condition linked to this snippet.","type":"integer","required":false},"active":{"description":"Snippet activation status.","type":"boolean","required":false},"priority":{"description":"Relative priority in which the snippet is executed.","type":"integer","required":false},"network":{"description":"Whether the snippet is network-wide instead of site-wide.","type":["boolean","null"],"required":false},"shared_network":{"description":"If a network snippet, whether can be activated on discrete sites instead of network-wide.","type":["boolean","null"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/snippets"}]}},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)":{"namespace":"code-snippets\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Descriptive title for the snippet.","type":"string","required":false},"desc":{"description":"Descriptive text associated with snippet.","type":"string","required":false},"code":{"description":"Executable snippet code.","type":"string","required":false},"tags":{"description":"List of tag categories the snippet belongs to.","type":"array","items":{"type":"string"},"required":false},"scope":{"description":"Context in which the snippet is executable.","type":"string","required":false},"condition_id":{"description":"Identifier of condition linked to this snippet.","type":"integer","required":false},"active":{"description":"Snippet activation status.","type":"boolean","required":false},"priority":{"description":"Relative priority in which the snippet is executed.","type":"integer","required":false},"network":{"description":"Whether the snippet is network-wide instead of site-wide.","type":["boolean","null"],"required":false},"shared_network":{"description":"If a network snippet, whether can be activated on discrete sites instead of network-wide.","type":["boolean","null"],"required":false}}},{"methods":["DELETE"],"args":[]}]},"\/code-snippets\/v1\/snippets\/schema":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/snippets\/schema"}]}},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/activate":{"namespace":"code-snippets\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/deactivate":{"namespace":"code-snippets\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/export":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/code-snippets\/v1\/snippets\/(?P<id>[\\d]+)\/export-code":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/code-snippets\/v1\/insert-headers-and-footers":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/insert-headers-and-footers"}]}},"\/code-snippets\/v1\/insert-headers-and-footers\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","required":false},"network":{"type":"boolean","required":false},"auto_add_tags":{"type":"boolean","required":false},"tag_value":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/insert-headers-and-footers\/import"}]}},"\/code-snippets\/v1\/header-footer-code-manager":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/header-footer-code-manager"}]}},"\/code-snippets\/v1\/header-footer-code-manager\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","required":false},"network":{"type":"boolean","required":false},"auto_add_tags":{"type":"boolean","required":false},"tag_value":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/header-footer-code-manager\/import"}]}},"\/code-snippets\/v1\/insert-php-code-snippet":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/insert-php-code-snippet"}]}},"\/code-snippets\/v1\/insert-php-code-snippet\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","required":false},"network":{"type":"boolean","required":false},"auto_add_tags":{"type":"boolean","required":false},"tag_value":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/insert-php-code-snippet\/import"}]}},"\/code-snippets\/v1\/importers":{"namespace":"code-snippets\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/importers"}]}},"\/code-snippets\/v1\/file-upload\/parse":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/file-upload\/parse"}]}},"\/code-snippets\/v1\/file-upload\/import":{"namespace":"code-snippets\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"snippets":{"description":"Array of snippet data to import","type":"array","required":true},"duplicate_action":{"description":"Action to take when duplicate snippets are found","type":"string","enum":["ignore","replace","skip"],"default":"ignore","required":false},"network":{"description":"Whether to import to network table","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/code-snippets\/v1\/file-upload\/import"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST","GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na komentare objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na komentare dodeljene posebnim ID-jevima korisnika. Zahteva ovla\u0161\u0107enje.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje komentare dodeljene posebnim korisni\u010dkim ID-jevima. Zahteva ovla\u0161\u0107enje.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Ograni\u010dite skup rezultata na one od posebne e-po\u0161te autora. Zahteva ovla\u0161\u0107enje.","format":"email","type":"string","required":false},"before":{"description":"Ograni\u010dite odgovor na komentare objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu komentara.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Ograni\u010dite skup rezultata na izvore sa posebnim roditeljskim ID-jevima.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Pobrinite se da skup rezultata isklju\u010duje posebne roditeljske ID-jeve.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ograni\u010dite skup rezultata na izvore dodeljene posebnim ID-jevima \u010dlanaka.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ograni\u010dite skup rezultata na komentare kojima je dodeljeno posebno stanje. Zahteva ovla\u0161\u0107enje.","type":"string","required":false},"type":{"default":"comment","description":"Ograni\u010dite skup rezultata na komentare kojima je dodeljena posebna vrsta. Zahteva ovla\u0161\u0107enje.","type":"string","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"ID predmeta korisnika, ako je autor korisnik.","type":"integer","required":false},"author_email":{"description":"Adresa e-po\u0161te autora komentara.","type":"string","format":"email","required":false},"author_ip":{"description":"IP adresa autora komentara.","type":"string","format":"ip","required":false},"author_name":{"description":"Ime za prikazivanje autora komentara.","type":"string","required":false},"author_url":{"description":"URL autora komentara.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Korisni\u010dki agent autora komentara.","type":"string","required":false},"content":{"description":"Sadr\u017eaj komentara.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj komentara, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj komentara, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum kada je komentar objavljen, u vremenskoj zoni veb mesta.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Datum kada je komentar objavljen, kao GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"ID roditelja komentara.","type":"integer","required":false},"post":{"default":0,"description":"ID povezan sa predmetom \u010dlanka.","type":"integer","required":false},"status":{"description":"Stanje komentara.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na komentare objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na komentare dodeljene posebnim ID-jevima korisnika. Zahteva ovla\u0161\u0107enje.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje komentare dodeljene posebnim korisni\u010dkim ID-jevima. Zahteva ovla\u0161\u0107enje.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Ograni\u010dite skup rezultata na one od posebne e-po\u0161te autora. Zahteva ovla\u0161\u0107enje.","format":"email","type":"string","required":false},"before":{"description":"Ograni\u010dite odgovor na komentare objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu komentara.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Ograni\u010dite skup rezultata na izvore sa posebnim roditeljskim ID-jevima.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Pobrinite se da skup rezultata isklju\u010duje posebne roditeljske ID-jeve.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ograni\u010dite skup rezultata na izvore dodeljene posebnim ID-jevima \u010dlanaka.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ograni\u010dite skup rezultata na komentare kojima je dodeljeno posebno stanje. Zahteva ovla\u0161\u0107enje.","type":"string","required":false},"type":{"default":"comment","description":"Ograni\u010dite skup rezultata na komentare kojima je dodeljena posebna vrsta. Zahteva ovla\u0161\u0107enje.","type":"string","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"ID predmeta korisnika, ako je autor korisnik.","type":"integer","required":false},"author_email":{"description":"Adresa e-po\u0161te autora komentara.","type":"string","format":"email","required":false},"author_ip":{"description":"IP adresa autora komentara.","type":"string","format":"ip","required":false},"author_name":{"description":"Ime za prikazivanje autora komentara.","type":"string","required":false},"author_url":{"description":"URL autora komentara.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Korisni\u010dki agent autora komentara.","type":"string","required":false},"content":{"description":"Sadr\u017eaj komentara.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj komentara, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj komentara, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum kada je komentar objavljen, u vremenskoj zoni veb mesta.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Datum kada je komentar objavljen, kao GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"ID roditelja komentara.","type":"integer","required":false},"post":{"default":0,"description":"ID povezan sa predmetom \u010dlanka.","type":"integer","required":false},"status":{"description":"Stanje komentara.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Jedinstveni identifikator komentara.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Lozinka roditeljskog \u010dlanka komentara (ako je \u010dlanak za\u0161ti\u0107en lozinkom).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Jedinstveni identifikator komentara.","type":"integer","required":false},"author":{"description":"ID predmeta korisnika, ako je autor korisnik.","type":"integer","required":false},"author_email":{"description":"Adresa e-po\u0161te autora komentara.","type":"string","format":"email","required":false},"author_ip":{"description":"IP adresa autora komentara.","type":"string","format":"ip","required":false},"author_name":{"description":"Ime za prikazivanje autora komentara.","type":"string","required":false},"author_url":{"description":"URL autora komentara.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Korisni\u010dki agent autora komentara.","type":"string","required":false},"content":{"description":"Sadr\u017eaj komentara.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj komentara, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj komentara, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum kada je komentar objavljen, u vremenskoj zoni veb mesta.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Datum kada je komentar objavljen, kao GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"ID roditelja komentara.","type":"integer","required":false},"post":{"description":"ID povezan sa predmetom \u010dlanka.","type":"integer","required":false},"status":{"description":"Stanje komentara.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Jedinstveni identifikator komentara.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false},"password":{"description":"Lozinka roditeljskog \u010dlanka komentara (ako je \u010dlanak za\u0161ti\u0107en lozinkom).","type":"string","required":false}}},{"methods":["GET"],"args":{"id":{"description":"Jedinstveni identifikator komentara.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Lozinka roditeljskog \u010dlanka komentara (ako je \u010dlanak za\u0161ti\u0107en lozinkom).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Jedinstveni identifikator komentara.","type":"integer","required":false},"author":{"description":"ID predmeta korisnika, ako je autor korisnik.","type":"integer","required":false},"author_email":{"description":"Adresa e-po\u0161te autora komentara.","type":"string","format":"email","required":false},"author_ip":{"description":"IP adresa autora komentara.","type":"string","format":"ip","required":false},"author_name":{"description":"Ime za prikazivanje autora komentara.","type":"string","required":false},"author_url":{"description":"URL autora komentara.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Korisni\u010dki agent autora komentara.","type":"string","required":false},"content":{"description":"Sadr\u017eaj komentara.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj komentara, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj komentara, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum kada je komentar objavljen, u vremenskoj zoni veb mesta.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Datum kada je komentar objavljen, kao GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"ID roditelja komentara.","type":"integer","required":false},"post":{"description":"ID povezan sa predmetom \u010dlanka.","type":"integer","required":false},"status":{"description":"Stanje komentara.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Note resolution status","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Jedinstveni identifikator komentara.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false},"password":{"description":"Lozinka roditeljskog \u010dlanka komentara (ako je \u010dlanak za\u0161ti\u0107en lozinkom).","type":"string","required":false}}}]},"\/wp-sync\/v1":{"namespace":"wp-sync\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-sync\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-sync\/v1"}]}},"\/wp-sync\/v1\/updates":{"namespace":"wp-sync\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"rooms":{"items":{"properties":{"after":{"minimum":0,"required":true,"type":"integer"},"awareness":{"required":true,"type":["object","null"]},"client_id":{"minimum":1,"required":true,"type":"integer"},"room":{"required":true,"type":"string","pattern":"^[^\/]+\/[^\/:]+(?::\\S+)?$"},"updates":{"items":{"properties":{"data":{"type":"string","required":true},"type":{"type":"string","required":true,"enum":["compaction","sync_step1","sync_step2","update"]}},"required":true,"type":"object"},"minItems":0,"required":true,"type":"array"}},"type":"object"},"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-sync\/v1\/updates"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<name>[a-z][a-z0-9-]*\/[a-z][a-z0-9-]*)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Icon name.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/settings":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-block-editor\/v1\/settings"}]}},"\/wp-block-editor\/v1\/assets":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-block-editor\/v1\/assets"}]}},"\/omgf\/v1":{"namespace":"omgf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"omgf\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/omgf\/v1"}]}},"\/omgf\/v1\/adminbar-menu\/status":{"namespace":"omgf\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/omgf\/v1\/adminbar-menu\/status"}]}},"\/omgf\/v1\/dashboard\/dismiss-notice":{"namespace":"omgf\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/omgf\/v1\/dashboard\/dismiss-notice"}]}},"\/litespeed\/v1":{"namespace":"litespeed\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"litespeed\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1"}]}},"\/litespeed\/v1\/toggle_crawler_state":{"namespace":"litespeed\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/toggle_crawler_state"}]}},"\/litespeed\/v1\/tool\/check_ip":{"namespace":"litespeed\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/tool\/check_ip"}]}},"\/litespeed\/v1\/guest\/sync":{"namespace":"litespeed\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/guest\/sync"}]}},"\/litespeed\/v3":{"namespace":"litespeed\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"litespeed\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v3"}]}},"\/litespeed\/v3\/ip_validate":{"namespace":"litespeed\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v3\/ip_validate"}]}},"\/litespeed\/v3\/wp_rest_echo":{"namespace":"litespeed\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v3\/wp_rest_echo"}]}},"\/litespeed\/v3\/ping":{"namespace":"litespeed\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v3\/ping"}]}},"\/litespeed\/v3\/cdn_status":{"namespace":"litespeed\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v3\/cdn_status"}]}},"\/litespeed\/v1\/notify_img":{"namespace":"litespeed\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/notify_img"}]}},"\/litespeed\/v1\/notify_ccss":{"namespace":"litespeed\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/notify_ccss"}]}},"\/litespeed\/v1\/notify_ucss":{"namespace":"litespeed\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/notify_ucss"}]}},"\/litespeed\/v1\/notify_vpi":{"namespace":"litespeed\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/notify_vpi"}]}},"\/litespeed\/v3\/err_domains":{"namespace":"litespeed\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v3\/err_domains"}]}},"\/litespeed\/v1\/check_img":{"namespace":"litespeed\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/litespeed\/v1\/check_img"}]}},"\/wpchill\/v1":{"namespace":"wpchill\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpchill\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wpchill\/v1"}]}},"\/wpchill\/v1\/notifications":{"namespace":"wpchill\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wpchill\/v1\/notifications"}]}},"\/wpchill\/v1\/notifications\/(?P<id>[\\w-]+)":{"namespace":"wpchill\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}]},"\/wpchill\/v1\/activate-plugin":{"namespace":"wpchill\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wpchill\/v1\/activate-plugin"}]}},"\/modula-best-grid-gallery\/v1":{"namespace":"modula-best-grid-gallery\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"modula-best-grid-gallery\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1"}]}},"\/modula-best-grid-gallery\/v1\/general-settings":{"namespace":"modula-best-grid-gallery\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/general-settings"}]}},"\/modula-best-grid-gallery\/v1\/general-settings-tabs":{"namespace":"modula-best-grid-gallery\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/general-settings-tabs"}]}},"\/modula-best-grid-gallery\/v1\/video\/youtube":{"namespace":"modula-best-grid-gallery\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/video\/youtube"}]}},"\/modula-best-grid-gallery\/v1\/video\/vimeo":{"namespace":"modula-best-grid-gallery\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/video\/vimeo"}]}},"\/modula-best-grid-gallery\/v1\/license":{"namespace":"modula-best-grid-gallery\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/license"}]}},"\/modula-best-grid-gallery\/v1\/extensions":{"namespace":"modula-best-grid-gallery\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/extensions"}]}},"\/modula-best-grid-gallery\/v1\/insights":{"namespace":"modula-best-grid-gallery\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/insights"}]}},"\/modula-best-grid-gallery\/v1\/menu":{"namespace":"modula-best-grid-gallery\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/menu"}]}},"\/modula-best-grid-gallery\/v1\/migrator\/install":{"namespace":"modula-best-grid-gallery\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugin_slug":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/migrator\/install"}]}},"\/modula-best-grid-gallery\/v1\/migrator\/activate":{"namespace":"modula-best-grid-gallery\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugin":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/migrator\/activate"}]}},"\/modula-best-grid-gallery\/v1\/migrator\/deactivate":{"namespace":"modula-best-grid-gallery\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugin":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-best-grid-gallery\/v1\/migrator\/deactivate"}]}},"\/performance-lab\/v1":{"namespace":"performance-lab\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"performance-lab\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/performance-lab\/v1"}]}},"\/performance-lab\/v1\/features\/(?P<slug>[a-z0-9_-]+):activate":{"namespace":"performance-lab\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Plugin slug of the Performance Lab feature to be activated.","required":true}}}]},"\/performance-lab\/v1\/features\/(?P<slug>[a-z0-9_-]+)":{"namespace":"performance-lab\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Plugin slug of plugin\/feature whose information is needed.","required":true}}}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/elementor-one\/v1":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-one\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1"}]}},"\/elementor-one\/v1\/connect\/authorize":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/connect\/authorize"}]}},"\/elementor-one\/v1\/connect\/disconnect":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/connect\/disconnect"}]}},"\/elementor-one\/v1\/connect\/switch-domain":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/connect\/switch-domain"}]}},"\/elementor-one\/v1\/connect\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/connect\/deactivate"}]}},"\/elementor-one\/v1\/top-bar\/notifications":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"app_name":{"type":"string","required":true},"app_version":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/top-bar\/notifications"}]}},"\/elementor-one\/v1\/top-bar\/feedback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product":{"type":"string","required":true},"subject":{"type":"string","required":true},"title":{"type":"string","required":true},"description":{"type":"string","required":true},"countryCode":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/top-bar\/feedback"}]}},"\/elementor-one\/v1\/themes":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The theme activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/themes"}]}},"\/elementor-one\/v1\/themes\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true}}}]},"\/elementor-one\/v1\/plugins":{"namespace":"elementor-one\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"status":{"description":"Ograni\u010dava rezultate na dodatke sa datim stanjem.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/plugins"}]}},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/upgrade":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["active"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/run":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true},"force":{"type":"boolean","default":true,"description":"Force migration even if the plugin is already connected.","required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/rollback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true}}}]},"\/elementor-one\/v1\/settings":{"namespace":"elementor-one\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-one\/v1\/settings"}]}},"\/pll\/v1":{"namespace":"pll\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"pll\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/pll\/v1"}]}},"\/pll\/v1\/languages":{"namespace":"pll\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"name":{"description":"Ime je kako se prikazuju na va\u0161em sajtu (na primer : engleski) ","type":"string","minLength":1,"required":false},"slug":{"description":"Jezi\u010dki kod - preporu\u010deno dvoslovna ISO 639-1 (na primer: en).","type":"string","pattern":"^[a-z][a-z0-9_-]*$","required":false},"locale":{"description":"Vordpres lokalizacija za jezik (na primer: en_US).","type":"string","pattern":"^[a-z]{2,3}(?:_[A-Z]{2})?(?:_[a-z0-9]+)?$","required":true},"is_rtl":{"description":"Smer teksta. `true` za zdesna na levo.","type":"boolean","required":false},"term_group":{"description":"Pozicija jezika u menja\u010du jezika.","type":"integer","required":false},"flag_code":{"description":"Kod zastave koji odgovara ISO 3166-1 (na primer: us za zastavu Sjedinjenih Ameri\u010dkih Dr\u017eava).","type":"string","required":false},"no_default_cat":{"default":false,"description":"Ozna\u010dava da li se podrazumevana kategorija mora kreirati prilikom dodavanja novog jezika.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/pll\/v1\/languages"}]}},"\/pll\/v1\/languages\/(?P<term_id>[\\d]+)":{"namespace":"pll\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"term_id":{"description":"Jedinstveni identifikator jezika.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"term_id":{"description":"Jedinstveni identifikator jezika.","type":"integer","required":false},"name":{"description":"Ime je kako se prikazuju na va\u0161em sajtu (na primer : engleski) ","type":"string","minLength":1,"required":false},"slug":{"description":"Jezi\u010dki kod - preporu\u010deno dvoslovna ISO 639-1 (na primer: en).","type":"string","pattern":"^[a-z][a-z0-9_-]*$","required":false},"locale":{"description":"Vordpres lokalizacija za jezik (na primer: en_US).","type":"string","pattern":"^[a-z]{2,3}(?:_[A-Z]{2})?(?:_[a-z0-9]+)?$","required":false},"is_rtl":{"description":"Smer teksta. `true` za zdesna na levo.","type":"boolean","required":false},"term_group":{"description":"Pozicija jezika u menja\u010du jezika.","type":"integer","required":false},"flag_code":{"description":"Kod zastave koji odgovara ISO 3166-1 (na primer: us za zastavu Sjedinjenih Ameri\u010dkih Dr\u017eava).","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"term_id":{"description":"Jedinstveni identifikator jezika.","type":"integer","required":false}}}]},"\/pll\/v1\/languages\/(?P<slug>[a-z][a-z0-9_-]*)":{"namespace":"pll\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Jezi\u010dki kod - preporu\u010deno dvoslovna ISO 639-1 (na primer: en).","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","edit"],"default":"view","required":false}}}]},"\/pll\/v1\/settings":{"namespace":"pll\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"browser":{"description":"Detektuj preferirani jezik pregleda\u010da na po\u010detnoj stranici: `true` za detekciju, `false` za nedetekciju.","type":"boolean","required":false},"rewrite":{"description":"Ukloni `\/language\/` iz stalnih veza: `true` za uklanjanje, `false` za zadr\u017eavanje.","type":"boolean","required":false},"hide_default":{"description":"Ukloni kod jezika iz URL-a za podrazumevani jezik: `true` za skrivanje, `false` za prikazivanje.","type":"boolean","required":false},"force_lang":{"description":"Odredite kako je trenutni jezik definisan.","type":"integer","enum":[1,2,3],"required":false},"redirect_lang":{"description":"Uklonite naziv stranice ili ID stranice iz URL-a po\u010detne stranice: `true` za uklanjanje, `false` za zadr\u017eavanje.","type":"boolean","required":false},"media_support":{"description":"Prevedi sadr\u017eaj: `true` za prevo\u0111enje, `false` u suprotnom.","type":"boolean","required":false},"sync":{"description":"Lista podataka za sinhronizaciju.","type":"array","items":{"type":"string","enum":["taxonomies","post_meta","comment_status","ping_status","sticky_posts","post_date","post_format","post_parent","_wp_page_template","menu_order","_thumbnail_id"]},"required":false},"post_types":{"description":"Lista tipova \u010dlanaka za prevo\u0111enje.","type":"array","items":{"type":"string"},"required":false},"taxonomies":{"description":"Lista taksonomija za prevo\u0111enje.","type":"array","items":{"type":"string"},"required":false},"domains":{"description":"Domeni koji se koriste kada je jezik pode\u0161en sa razli\u010ditih domena.","type":"object","additionalProperties":false,"patternProperties":{"^[a-z][a-z0-9_-]*$":{"type":"string","format":"uri"}},"required":false},"default_lang":{"description":"Podlo\u017eak podrazumevanog jezika.","type":"string","pattern":"^[a-z][a-z0-9_-]*$","required":false},"nav_menus":{"description":"Prevedeni navigacioni izbornici za svaku temu.","type":"object","additionalProperties":false,"patternProperties":{"[^\\\/:<>\\*\\?\"\\|]+":{"type":"object","patternProperties":{"[\\w-]+":{"type":"object","patternProperties":{"^[a-z][a-z0-9_-]*$":{"type":"integer","minimum":0}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/pll\/v1\/settings"}]}},"\/complianz\/v1":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"complianz\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1"}]}},"\/complianz\/v1\/documents":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/documents"}]}},"\/complianz\/v1\/banner":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/banner"}]}},"\/complianz\/v1\/track":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/track"}]}},"\/complianz\/v1\/manage_consent_html":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/manage_consent_html"}]}},"\/complianz\/v1\/store_cookies":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/store_cookies"}]}},"\/complianz\/v1\/consent-area\/(?P<post_id>([0-9]+))\/(?P<block_id>([a-z0-9-_]+))":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/complianz\/v1\/datarequests":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/datarequests"}]}},"\/complianz\/v1\/cookie_data":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/cookie_data"}]}},"\/complianz\/v1\/wsc-scan":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/wsc-scan"}]}},"\/complianz\/v1\/wsc-checks":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/complianz\/v1\/wsc-checks"}]}},"\/modula-ai-image-descriptor\/v1":{"namespace":"modula-ai-image-descriptor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"modula-ai-image-descriptor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1"}]}},"\/modula-ai-image-descriptor\/v1\/gallery-status\/(?P<id>\\d+)":{"namespace":"modula-ai-image-descriptor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/modula-ai-image-descriptor\/v1\/gallery-debug\/(?P<id>\\d+)":{"namespace":"modula-ai-image-descriptor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/modula-ai-image-descriptor\/v1\/optimize-gallery":{"namespace":"modula-ai-image-descriptor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/optimize-gallery"}]}},"\/modula-ai-image-descriptor\/v1\/stop-optimizing-gallery":{"namespace":"modula-ai-image-descriptor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/stop-optimizing-gallery"}]}},"\/modula-ai-image-descriptor\/v1\/ai-settings":{"namespace":"modula-ai-image-descriptor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/ai-settings"}]}},"\/modula-ai-image-descriptor\/v1\/generate-alt-text":{"namespace":"modula-ai-image-descriptor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/generate-alt-text"}]}},"\/modula-ai-image-descriptor\/v1\/get-ai-user":{"namespace":"modula-ai-image-descriptor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/get-ai-user"}]}},"\/modula-ai-image-descriptor\/v1\/update-alts-from-image-array":{"namespace":"modula-ai-image-descriptor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/update-alts-from-image-array"}]}},"\/modula-ai-image-descriptor\/v1\/cleanup-galleries":{"namespace":"modula-ai-image-descriptor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/modula-ai-image-descriptor\/v1\/cleanup-galleries"}]}},"\/newsletter":{"namespace":"newsletter","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"newsletter","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/newsletter"}]}},"\/newsletter\/manager":{"namespace":"newsletter","methods":["POST","GET"],"endpoints":[{"methods":["POST","GET"],"args":{"k":{"required":true},"what":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/newsletter\/manager"}]}},"\/ea11y\/v1":{"namespace":"ea11y\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ea11y\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1"}]}},"\/ea11y\/v1\/connect\/authorize":{"namespace":"ea11y\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/connect\/authorize"}]}},"\/ea11y\/v1\/connect\/disconnect":{"namespace":"ea11y\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/connect\/disconnect"}]}},"\/ea11y\/v1\/connect\/switch-domain":{"namespace":"ea11y\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/connect\/switch-domain"}]}},"\/ea11y\/v1\/connect\/deactivate":{"namespace":"ea11y\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/connect\/deactivate"}]}},"\/ea11y\/v1\/settings\/get-settings":{"namespace":"ea11y\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/settings\/get-settings"}]}},"\/ea11y\/v1\/settings\/get-media":{"namespace":"ea11y\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/settings\/get-media"}]}},"\/ea11y\/v1\/analytics\/statistic":{"namespace":"ea11y\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/analytics\/statistic"}]}},"\/ea11y\/v1\/reviews\/review":{"namespace":"ea11y\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/ea11y\/v1\/reviews\/review"}]}},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true}}}]},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/design-system-sync\/stylesheet":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/design-system-sync\/stylesheet"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/operations\/opt-in-v4":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/operations\/opt-in-v4"}]}},"\/elementor\/v1\/feedback":{"namespace":"elementor\/v1\/feedback","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/feedback","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/feedback"}]}},"\/elementor\/v1\/feedback\/submit":{"namespace":"elementor\/v1\/feedback","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/feedback\/submit"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/elementor\/v1\/onboarding":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/onboarding"}]}},"\/elementor\/v1\/onboarding\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/onboarding\/user-progress"}]}},"\/elementor\/v1\/onboarding\/user-choices":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/onboarding\/user-choices"}]}},"\/elementor\/v1\/onboarding\/pro-install-screen":{"namespace":"elementor\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/onboarding\/pro-install-screen"}]}},"\/elementor\/v1\/onboarding\/install-pro":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/onboarding\/install-pro"}]}},"\/elementor\/v1\/onboarding\/install-theme":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/onboarding\/install-theme"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"Whether to only regenerate missing thumbnails. It's faster with this enabled.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"Whether to delete any old, now unregistered thumbnail files.","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"Whether to update the image tags in any posts that make use of this attachment.","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"The types of posts to update. Defaults to all public post types.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Specific post IDs to update rather than any posts that use this attachment.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Posts to process per loop. This is to control memory usage and you likely don't need to adjust this.","type":"integer","default":10,"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Ograni\u010dite skup rezultata na osnovu veze izme\u0111u vi\u0161e taksonomija.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ograni\u010dite skup rezultata na sve stavke koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji categories.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Da li da se podre\u0111eni \u010dlanovi uklju\u010duju u \u010dlanove ograni\u010davaju\u0107i skup rezultata.","type":"boolean","default":false},"operator":{"description":"Da li stavke moraju biti dodeljene svim ili bilo kojim navedenim \u010dlanovima.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ograni\u010dite skup rezultata na sve stavke izuzev onih koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji categories.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Da li da se podre\u0111eni \u010dlanovi uklju\u010duju u \u010dlanove ograni\u010davaju\u0107i skup rezultata.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ograni\u010dite skup rezultata na sve stavke koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji tags.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Da li stavke moraju biti dodeljene svim ili bilo kojim navedenim \u010dlanovima.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ograni\u010dite skup rezultata na sve stavke izuzev onih koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji tags.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Ograni\u010dite skup rezultata na stavke koje su lepljive.","type":"boolean","required":false},"ignore_sticky":{"description":"Da li ignorisati lepljive \u010dlanke ili ne.","type":"boolean","default":true,"required":false},"format":{"description":"Ograni\u010dite skup rezultata na stavke kojima je dodeljen jedan ili vi\u0161e datih oblika.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Oblik \u010dlanka.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Da li bi trebalo ili ne bi trebalo da se sa \u010dlankom postupa kao lepljivim.","type":"boolean","required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"categories":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Promenite podrazumevanu du\u017einu ise\u010dka.","type":"integer","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Oblik \u010dlanka.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Da li bi trebalo ili ne bi trebalo da se sa \u010dlankom postupa kao lepljivim.","type":"boolean","required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"categories":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Oblik \u010dlanka.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Da li bi trebalo ili ne bi trebalo da se sa \u010dlankom postupa kao lepljivim.","type":"boolean","required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"categories":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa posebnom vredno\u0161\u0107u menu_order.","type":"integer","required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Ograni\u010dite skup rezultata na stavke sa posebnim ID-jem roditelja.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ograni\u010dite skup rezultata na sve stavke sem onih sa posebnim ID-jem roditelja.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"orderby_hierarchy":{"description":"Sort pages by hierarchy.","type":"boolean","default":false,"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"parent":{"description":"ID roditelja \u010dlanka.","type":"integer","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Redosled \u010dlanaka u odnosu na druge \u010dlanke.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Promenite podrazumevanu du\u017einu ise\u010dka.","type":"integer","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"parent":{"description":"ID roditelja \u010dlanka.","type":"integer","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Redosled \u010dlanaka u odnosu na druge \u010dlanke.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID roditelja \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Redosled \u010dlanaka u odnosu na druge \u010dlanke.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Ograni\u010dite skup rezultata na stavke sa posebnim ID-jem roditelja.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ograni\u010dite skup rezultata na sve stavke sem onih sa posebnim ID-jem roditelja.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limit result set to attachments of a particular media type or media types.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limit result set to attachments of a particular MIME type or MIME types.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"filename":{"description":"Original attachment file name","type":"string","required":false},"filesize":{"description":"Attachment file size","type":"number","required":false},"alt_text":{"description":"Rezervni tekst za prikaz kada prilog nije prikazan.","type":"string","required":false},"caption":{"description":"Natpis priloga.","type":"object","properties":{"raw":{"description":"Natpis priloga, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML natpis priloga, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis priloga.","type":"object","properties":{"raw":{"description":"Opis priloga, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML opis priloga, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID povezanog \u010dlanka priloga.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Whether to generate image sub sizes.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Whether to convert image formats.","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"comment_status":{"description":"Da li su ili nisu komentari otvoreni na \u010dlanku.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Da li mo\u017ee ili ne mo\u017ee \u010dlanku da se uputi ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"filename":{"description":"Original attachment file name","type":"string","required":false},"filesize":{"description":"Attachment file size","type":"number","required":false},"alt_text":{"description":"Rezervni tekst za prikaz kada prilog nije prikazan.","type":"string","required":false},"caption":{"description":"Natpis priloga.","type":"object","properties":{"raw":{"description":"Natpis priloga, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML natpis priloga, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis priloga.","type":"object","properties":{"raw":{"description":"Opis priloga, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML opis priloga, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID povezanog \u010dlanka priloga.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Jedinstveni identifikator priloga.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL ka ure\u0111enoj datoteci slike.","type":"string","format":"uri","required":true},"modifiers":{"description":"Niz ure\u0111ivanja slike.","type":"array","minItems":1,"items":{"description":"Ure\u0111ivanje slike.","type":"object","required":["type","args"],"oneOf":[{"title":"Flip","properties":{"type":{"description":"Flip type.","type":"string","enum":["flip"]},"args":{"description":"Flip arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Flip direction.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Whether to flip in the horizontal direction.","type":"boolean"},"vertical":{"description":"Whether to flip in the vertical direction.","type":"boolean"}}}}}}},{"title":"Okretanje","properties":{"type":{"description":"Vrsta okretanja.","type":"string","enum":["rotate"]},"args":{"description":"Argumenti okretanja.","type":"object","required":["angle"],"properties":{"angle":{"description":"Ugao za okretanje slike u smeru kazaljke na satu u stepenima.","type":"number"}}}}},{"title":"Opseci","properties":{"type":{"description":"Vrsta opsecanja.","type":"string","enum":["crop"]},"args":{"description":"Argumenti opsecanja.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Vodoravni polo\u017eaj sleva da bi zapo\u010delo opsecanje kao procenat \u0161irine slike.","type":"number"},"top":{"description":"Uspravni polo\u017eaj od vrha da bi zapo\u010delo opsecanje kao procenat visine slike.","type":"number"},"width":{"description":"\u0160irina opsecanja u procentima \u0161irine slike.","type":"number"},"height":{"description":"Visina opsecanja u procentima visine slike.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Iznos za okretanje slike u smeru kazaljke na satu u stepenima. ZASTARELO: Umesto toga, koristite `modifiers`.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Kao procenat slike, x pozicija od po\u010detka za zapo\u010dinjanje opsecanja. ZASTARELO: Umesto toga, koristite `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Kao procenat slike, y pozicija od po\u010detka za zapo\u010dinjanje opsecanja. ZASTARELO: Umesto toga, koristite `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Kao procenat slike, \u0161irina za opsecanje slike. ZASTARELO: Umesto toga, koristite `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Kao procenat slike, visina za opsecanje slike. ZASTARELO: Umesto toga, koristite `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Natpis priloga.","type":"object","properties":{"raw":{"description":"Natpis priloga, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML natpis priloga, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis priloga.","type":"object","properties":{"raw":{"description":"Opis priloga, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML opis priloga, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"ID povezanog \u010dlanka priloga.","type":"integer","required":false},"alt_text":{"description":"Rezervni tekst za prikaz kada prilog nije prikazan.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the attachment.","type":"integer","required":false},"image_size":{"description":"Image size.","type":"string","enum":["thumbnail","medium","medium_large","large","1536x1536","2048x2048","bunyad-small","bunyad-medium","bunyad-full","bunyad-viewport","bunyad-768","original","scaled","full"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the attachment.","type":"integer","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Ograni\u010dite skup rezultata na osnovu veze izme\u0111u vi\u0161e taksonomija.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ograni\u010dite skup rezultata na sve stavke koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji menus.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Da li stavke moraju biti dodeljene svim ili bilo kojim navedenim \u010dlanovima.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ograni\u010dite skup rezultata na sve stavke izuzev onih koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji menus.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa posebnom vredno\u0161\u0107u menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Naslov predmeta.","type":["string","object"],"properties":{"raw":{"description":"Naslov predmeta, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov predmeta, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Porodica objekata koje su prvobitno predstavljene, kao \u0161to su \"post_type\" ili \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Imenovano stanje predmeta.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"ID roditelja predmeta.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Tekst za naslovni atribut elementa veze za ovu stavku izbornika.","type":"string","required":false},"classes":{"description":"Klasni nazivi za element veze ove stavke izbornika.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis ove stavke izbornika.","type":"string","required":false},"menu_order":{"default":1,"description":"DB ID izbornika navigacione stavke koji je roditelj ove stavke, ako postoji, u suprotnom 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Vrsta objekta koji je prvobitno predstavljen, kao \u0161to su \"kategorija\", \"\u010dlanak\" ili \"prilog\".","type":"string","required":false},"object_id":{"default":0,"description":"ID baze podataka originalnog objekta koji ova stavka izbornika predstavlja, na primer ID za \u010dlanke ili term_id za kategorije.","type":"integer","minimum":0,"required":false},"target":{"description":"Ciljni atribut elementa veze za ovu stavku izbornika.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL na koji ova stavka izbornika pokazuje.","type":"string","format":"uri","required":false},"xfn":{"description":"XFN veza izra\u017eena u vezi ove stavke izbornika.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u010clanovi dodeljeni predmetu u taksonomiji nav_menu.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"_pll_menu_item":{"type":"object","title":"","description":"Pode\u0161avanje promene jezika","default":[],"additionalProperties":{"type":"boolean"}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"title":{"description":"Naslov predmeta.","type":["string","object"],"properties":{"raw":{"description":"Naslov predmeta, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov predmeta, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Porodica objekata koje su prvobitno predstavljene, kao \u0161to su \"post_type\" ili \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Imenovano stanje predmeta.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"ID roditelja predmeta.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Tekst za naslovni atribut elementa veze za ovu stavku izbornika.","type":"string","required":false},"classes":{"description":"Klasni nazivi za element veze ove stavke izbornika.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis ove stavke izbornika.","type":"string","required":false},"menu_order":{"description":"DB ID izbornika navigacione stavke koji je roditelj ove stavke, ako postoji, u suprotnom 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Vrsta objekta koji je prvobitno predstavljen, kao \u0161to su \"kategorija\", \"\u010dlanak\" ili \"prilog\".","type":"string","required":false},"object_id":{"description":"ID baze podataka originalnog objekta koji ova stavka izbornika predstavlja, na primer ID za \u010dlanke ili term_id za kategorije.","type":"integer","minimum":0,"required":false},"target":{"description":"Ciljni atribut elementa veze za ovu stavku izbornika.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL na koji ova stavka izbornika pokazuje.","type":"string","format":"uri","required":false},"xfn":{"description":"XFN veza izra\u017eena u vezi ove stavke izbornika.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u010clanovi dodeljeni predmetu u taksonomiji nav_menu.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"_pll_menu_item":{"type":"object","title":"","description":"Pode\u0161avanje promene jezika","default":[],"additionalProperties":{"type":"boolean"}}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID roditelja predmeta.","type":"integer","minimum":0,"required":false},"title":{"description":"Naslov predmeta.","type":["string","object"],"properties":{"raw":{"description":"Naslov predmeta, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov predmeta, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Porodica objekata koje su prvobitno predstavljene, kao \u0161to su \"post_type\" ili \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Imenovano stanje predmeta.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Tekst za naslovni atribut elementa veze za ovu stavku izbornika.","type":"string","required":false},"classes":{"description":"Klasni nazivi za element veze ove stavke izbornika.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis ove stavke izbornika.","type":"string","required":false},"menu_order":{"description":"DB ID izbornika navigacione stavke koji je roditelj ove stavke, ako postoji, u suprotnom 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Vrsta objekta koji je prvobitno predstavljen, kao \u0161to su \"kategorija\", \"\u010dlanak\" ili \"prilog\".","type":"string","required":false},"object_id":{"description":"ID baze podataka originalnog objekta koji ova stavka izbornika predstavlja, na primer ID za \u010dlanke ili term_id za kategorije.","type":"integer","minimum":0,"required":false},"target":{"description":"Ciljni atribut elementa veze za ovu stavku izbornika.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL na koji ova stavka izbornika pokazuje.","type":"string","format":"uri","required":false},"xfn":{"description":"XFN veza izra\u017eena u vezi ove stavke izbornika.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u010clanovi dodeljeni predmetu u taksonomiji nav_menu.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"_pll_menu_item":{"type":"object","title":"","description":"Pode\u0161avanje promene jezika","default":[],"additionalProperties":{"type":"boolean"}}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Ograni\u010dite skup rezultata na osnovu veze izme\u0111u vi\u0161e taksonomija.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ograni\u010dite skup rezultata na sve stavke koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Da li stavke moraju biti dodeljene svim ili bilo kojim navedenim \u010dlanovima.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ograni\u010dite skup rezultata na sve stavke izuzev onih koji imaju odre\u0111ene \u010dlanove dodeljene taksonomiji wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Spisak ID-jeva \u010dlanova","description":"Poklopite \u010dlanove sa navedenim ID-jevima.","type":"array","items":{"type":"integer"}},{"title":"Upit taksonomije ID-a \u010dlana","description":"Izvr\u0161ite napredni upit \u010dlanova.","type":"object","properties":{"terms":{"description":"ID-ovi \u010dlanova.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"wp_pattern_category":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Promenite podrazumevanu du\u017einu ise\u010dka.","type":"integer","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"wp_pattern_category":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false},"wp_pattern_category":{"description":"\u010clanovi dodeljeni \u010dlanku u taksonomiji wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/created-templates\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/created-templates\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/created-templates\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}]},"\/wp\/v2\/created-templates\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/created-templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/created-templates"}]}},"\/wp\/v2\/created-templates\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Promenite podrazumevanu du\u017einu ise\u010dka.","type":"integer","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"excerpt":{"description":"Ise\u010dak \u010dlanka.","type":"object","properties":{"raw":{"description":"Ise\u010dak \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML ise\u010dak \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Da li je ise\u010dak za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"slug":{"description":"Jedinstveni podlo\u017eak koji identifikuje \u0161ablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifikator teme za \u0161ablon.","type":"string","required":false},"type":{"description":"Vrsta \u0161ablona.","type":"string","required":false},"content":{"description":"Sadr\u017eaj \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Sadr\u017eaj za \u0161ablon, kakav je u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika bloka sadr\u017eaja koji koristi \u0161ablon.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Naslov \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Naslov za \u0161ablon, kakav u bazi podataka.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML naslov za \u0161ablon, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis \u0161ablona.","type":"string","required":false},"status":{"description":"Stanje \u0161ablona.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID za autora \u0161ablona.","type":"integer","required":false},"area":{"description":"Gde je deo \u0161ablona namenjen za kori\u0161\u0107enje (zaglavlje, podno\u017eje, itd.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Ograni\u010di na odre\u0111eni identifikator \u010dlanka.","type":"integer","required":false},"area":{"description":"Ograni\u010di na odre\u0111eni prostor dela \u0161ablona.","type":"string","required":false},"post_type":{"description":"Vrsta \u010dlanka za koju \u0107ete dobiti \u0161ablone.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Jedinstveni podlo\u017eak koji identifikuje \u0161ablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifikator teme za \u0161ablon.","type":"string","required":false},"type":{"description":"Vrsta \u0161ablona.","type":"string","required":false},"content":{"default":"","description":"Sadr\u017eaj \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Sadr\u017eaj za \u0161ablon, kakav je u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika bloka sadr\u017eaja koji koristi \u0161ablon.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Naslov \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Naslov za \u0161ablon, kakav u bazi podataka.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML naslov za \u0161ablon, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Opis \u0161ablona.","type":"string","required":false},"status":{"default":"publish","description":"Stanje \u0161ablona.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID za autora \u0161ablona.","type":"integer","required":false},"area":{"description":"Gde je deo \u0161ablona namenjen za kori\u0161\u0107enje (zaglavlje, podno\u017eje, itd.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Podlo\u017eak \u0161ablona za dobijanje alternative","type":"string","required":true},"is_custom":{"description":"Ozna\u010dava da li je \u0161ablon prilago\u0111en ili deo hijerarhije \u0161ablona","type":"boolean","required":false},"template_prefix":{"description":"Prefiks \u0161ablona za napravljeni \u0161ablon. Ovo se koristi za izdvajanje glavnog tipa \u0161ablona, na primer, u `taxonomy-books` izdvaja `taxonomy`.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"slug":{"description":"Jedinstveni podlo\u017eak koji identifikuje \u0161ablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifikator teme za \u0161ablon.","type":"string","required":false},"type":{"description":"Vrsta \u0161ablona.","type":"string","required":false},"content":{"description":"Sadr\u017eaj \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Sadr\u017eaj za \u0161ablon, kakav je u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika bloka sadr\u017eaja koji koristi \u0161ablon.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Naslov \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Naslov za \u0161ablon, kakav u bazi podataka.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML naslov za \u0161ablon, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis \u0161ablona.","type":"string","required":false},"status":{"description":"Stanje \u0161ablona.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID za autora \u0161ablona.","type":"integer","required":false},"area":{"description":"Gde je deo \u0161ablona namenjen za kori\u0161\u0107enje (zaglavlje, podno\u017eje, itd.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID za roditelja revizije globalnih stilova.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator za reviziju globalnih stilova.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"The theme identifier","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"The theme identifier","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"The id of a template","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Global styles.","type":["object"],"required":false},"settings":{"description":"Global settings.","type":["object"],"required":false},"title":{"description":"Title of the global styles variation.","type":["object","string"],"properties":{"raw":{"description":"Title for the global styles variation, as it exists in the database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML title for the post, transformed for display.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Sadr\u017eaj \u010dlanka.","type":"object","properties":{"raw":{"description":"Sadr\u017eaj \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML sadr\u017eaj \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Izdanje oblika sadr\u017eaja bloka koji koristi \u010dlanak.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Da li je sadr\u017eaj za\u0161ti\u0107en lozinkom.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja automatskog snimanja.","type":"integer","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Verzija theme.JSON \u0161eme koja se koristi za pode\u0161avanja tipografije.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklaracija font-family u oblik theme.json, kodirana kao string.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"theme_json_version":{"description":"Verzija theme.JSON \u0161eme koja se koristi za pode\u0161avanja tipografije.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklaracija font-family u oblik theme.json, kodirana kao string.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"ID za nadre\u0111enu porodicu fontova.","type":"integer","required":true},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"ID za nadre\u0111enu porodicu fontova.","type":"integer","required":true},"theme_json_version":{"description":"Verzija theme.JSON \u0161eme koja se koristi za pode\u0161avanja tipografije.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"deklaracija font-face u oblik theme.json, kodirana kao niz.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"ID za nadre\u0111enu porodicu fontova.","type":"integer","required":true},"id":{"description":"Jedinstveni identifikator za oblik fonta.","type":"integer","required":true},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"ID za nadre\u0111enu porodicu fontova.","type":"integer","required":true},"id":{"description":"Jedinstveni identifikator za oblik fonta.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ograni\u010dite skup rezultata na \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje \u010dlanke dodeljene posebnim autorima.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID autora \u010dlanka.","type":"integer","required":false},"featured_media":{"description":"ID izdvojenog sadr\u017eaja \u010dlanka.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"_crdt_document":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","ts-archive","ts-footer","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID roditelja revizije.","type":"integer","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/modula-gallery":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene posle datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ograni\u010dite odgovor na \u010dlanke objavljene pre datog datuma uskla\u0111enog sa ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kako protuma\u010diti unos za pretragu.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanke sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/modula-gallery"}]}},"\/wp\/v2\/modula-gallery\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Lozinka \u010dlanka ako je za\u0161ti\u0107en lozinkom.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"date":{"description":"Datum kada je \u010dlanak objavljen, u vremenskoj zoni veb mesta.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Datum kada je \u010dlanak objavljen, kao GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlanka jedinstvene vrste.","type":"string","required":false},"status":{"description":"Imenovano stanje \u010dlanka.","type":"string","enum":["publish","future","draft","pending","private","auto-draft"],"required":false},"password":{"description":"Lozinka za za\u0161titu pristupa sadr\u017eaju i ise\u010dku.","type":"string","required":false},"title":{"description":"Naslov \u010dlanka.","type":"object","properties":{"raw":{"description":"Naslov \u010dlanka, kao \u0161to postoji u bazi podataka.","type":"string","context":["edit"]},"rendered":{"description":"HTML naslov \u010dlanka, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Datoteka teme koja se koristi za prikaz \u010dlanka.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlanka.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Alfanumeri\u010dki identifikator vrste \u010dlanka.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Alfanumeri\u010dki identifikator stanja.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ograni\u010dite rezultate na taksonomije povezane sa posebnom vrstom unosa.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Alfanumeri\u010dki identifikator taksonomije.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini \u010dlana.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Da li da se sakriju \u010dlanovi koji nisu dodeljeni bilo kom \u010dlanku.","type":"boolean","default":false,"required":false},"parent":{"description":"Ograni\u010dite skup rezultata na \u010dlanove kojima je dodeljen poseban roditelj.","type":"integer","required":false},"post":{"description":"Ograni\u010dite skup rezultata na \u010dlanove kojima je dodeljen poseban \u010dlanak.","type":"integer","default":null,"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanove sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":true},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"parent":{"description":"ID nadre\u0111enog \u010dlana.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"parent":{"description":"ID nadre\u0111enog \u010dlana.","type":"integer","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to \u010dlanovi ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini \u010dlana.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Da li da se sakriju \u010dlanovi koji nisu dodeljeni bilo kom \u010dlanku.","type":"boolean","default":false,"required":false},"post":{"description":"Ograni\u010dite skup rezultata na \u010dlanove kojima je dodeljen poseban \u010dlanak.","type":"integer","default":null,"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanove sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":true},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to \u010dlanovi ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini \u010dlana.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Da li da se sakriju \u010dlanovi koji nisu dodeljeni bilo kom \u010dlanku.","type":"boolean","default":false,"required":false},"post":{"description":"Ograni\u010dite skup rezultata na \u010dlanove kojima je dodeljen poseban \u010dlanak.","type":"integer","default":null,"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanove sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":true},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false},"locations":{"description":"Lokacije dodeljene izborniku.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Da li da automatski dodate stranice na vrhu nivoa u ovaj izbornik.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false},"locations":{"description":"Lokacije dodeljene izborniku.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Da li da automatski dodate stranice na vrhu nivoa u ovaj izbornik.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to \u010dlanovi ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini \u010dlana.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Da li da se sakriju \u010dlanovi koji nisu dodeljeni bilo kom \u010dlanku.","type":"boolean","default":false,"required":false},"post":{"description":"Ograni\u010dite skup rezultata na \u010dlanove kojima je dodeljen poseban \u010dlanak.","type":"integer","default":null,"required":false},"slug":{"description":"Ograni\u010dite skup rezultata na \u010dlanove sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":true},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"description":{"description":"HTML opis \u010dlana.","type":"string","required":false},"name":{"description":"HTML naslov \u010dlana.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator \u010dlana jedinstvene vrste.","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator \u010dlana.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to \u010dlanovi ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"default":"asc","description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sortiraj kolekciju po atributu korisnika.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ograni\u010dite skup rezultata na korisnike sa jednim ili vi\u0161e posebnih podlo\u017eaka.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ograni\u010dite skup rezultata izvora koji odgovaraju barem jednoj posebnoj dostavljenoj ulozi. Prihvata csv spisak ili jednu ulogu.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Ograni\u010di skup rezultata na korisnike koji odgovaraju bar jednom konkretnom sposobno\u0161\u0107u. Prihvata spisak sposobnosti razdvojen zarezima ili pojedina\u010dnu sposobnost.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ograni\u010dite skup rezultata na korisnike koji se smatraju autorima.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Ograni\u010di skup rezultata na korisnike koji su objavili \u010dlanke.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","elementor_library":"elementor_library","modula-gallery":"modula-gallery"}},"required":false},"search_columns":{"default":[],"description":"Niz imena kolona koje treba pretra\u017eiti","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Ime za prijavu korisnika.","type":"string","required":true},"name":{"description":"Ime za prikazivanje korisnika.","type":"string","required":false},"first_name":{"description":"Ime korisnika.","type":"string","required":false},"last_name":{"description":"Prezime korisnika.","type":"string","required":false},"email":{"description":"Adresa e-po\u0161te korisnika.","type":"string","format":"email","required":true},"url":{"description":"URL korisnika.","type":"string","format":"uri","required":false},"description":{"description":"Opis korisnika.","type":"string","required":false},"locale":{"description":"Lokalizacija korisnika.","type":"string","enum":["","en_US","en_GB","sr_RS"],"required":false},"nickname":{"description":"Nadimak korisnika.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator korisnika.","type":"string","required":false},"roles":{"description":"Uloge dodeljene korisniku.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Lozinka korisnika (nikada nije uklju\u010deno).","type":"string","required":true},"meta":{"description":"Meta polja.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Datum i vreme kada su preference a\u017eurirane.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator korisnika.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator korisnika.","type":"integer","required":false},"username":{"description":"Ime za prijavu korisnika.","type":"string","required":false},"name":{"description":"Ime za prikazivanje korisnika.","type":"string","required":false},"first_name":{"description":"Ime korisnika.","type":"string","required":false},"last_name":{"description":"Prezime korisnika.","type":"string","required":false},"email":{"description":"Adresa e-po\u0161te korisnika.","type":"string","format":"email","required":false},"url":{"description":"URL korisnika.","type":"string","format":"uri","required":false},"description":{"description":"Opis korisnika.","type":"string","required":false},"locale":{"description":"Lokalizacija korisnika.","type":"string","enum":["","en_US","en_GB","sr_RS"],"required":false},"nickname":{"description":"Nadimak korisnika.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator korisnika.","type":"string","required":false},"roles":{"description":"Uloge dodeljene korisniku.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Lozinka korisnika (nikada nije uklju\u010deno).","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Datum i vreme kada su preference a\u017eurirane.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator korisnika.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to korisnici ne podr\u017eavaju preme\u0161tanje na otpad.","required":false},"reassign":{"type":"integer","description":"Dodeli \u010dlanke i veze obrisanog korisnika ovom korisni\u010dkom ID-ju.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Ime za prijavu korisnika.","type":"string","required":false},"name":{"description":"Ime za prikazivanje korisnika.","type":"string","required":false},"first_name":{"description":"Ime korisnika.","type":"string","required":false},"last_name":{"description":"Prezime korisnika.","type":"string","required":false},"email":{"description":"Adresa e-po\u0161te korisnika.","type":"string","format":"email","required":false},"url":{"description":"URL korisnika.","type":"string","format":"uri","required":false},"description":{"description":"Opis korisnika.","type":"string","required":false},"locale":{"description":"Lokalizacija korisnika.","type":"string","enum":["","en_US","en_GB","sr_RS"],"required":false},"nickname":{"description":"Nadimak korisnika.","type":"string","required":false},"slug":{"description":"Alfanumeri\u010dki identifikator korisnika.","type":"string","required":false},"roles":{"description":"Uloge dodeljene korisniku.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Lozinka korisnika (nikada nije uklju\u010deno).","type":"string","required":false},"meta":{"description":"Meta polja.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Datum i vreme kada su preference a\u017eurirane.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to korisnici ne podr\u017eavaju preme\u0161tanje na otpad.","required":false},"reassign":{"type":"integer","description":"Dodeli \u010dlanke i veze obrisanog korisnika ovom korisni\u010dkom ID-ju.","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"uuid koji je aplikacija obezbedila da bi se jedinstveno identifikovala. Preporu\u010duje se kori\u0161\u0107enje UUID v5 sa URL-om ili DNS imenom prostora.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Ime lozinke aplikacije.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"uuid koji je aplikacija obezbedila da bi se jedinstveno identifikovala. Preporu\u010duje se kori\u0161\u0107enje UUID v5 sa URL-om ili DNS imenom prostora.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Ime lozinke aplikacije.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"type":{"default":"post","description":"Ograni\u010dite rezultate na stavke vrste predmeta.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ograni\u010dite rezultate na stavke jedne ili vi\u0161e podvrsta predmeta.","type":"array","items":{"enum":["post","page","elementor_library","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Jedinstveno registrovano ime bloka.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atributi bloka.","type":"object","default":[],"required":false},"post_id":{"description":"ID zna\u010denja \u010dlanka.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Ime prostora bloka.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Ime prostora bloka.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Ime bloka.","type":"string","required":false},"namespace":{"description":"Ime prostora bloka.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"active_templates":{"title":"Active Templates","description":"","type":"object","additionalProperties":true,"required":false},"title":{"title":"Naslov","description":"Naslov veb mesta.","type":"string","required":false},"description":{"title":"Podnaslov","description":"Podnaslov veb mesta.","type":"string","required":false},"url":{"title":"","description":"URL veb mesta.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Ova adresa se koristi samo za upravlja\u010dke svrhe, kao \u0161to je obave\u0161tavanje novih korisnika.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Grad koji je u istoj vremenskoj zoni kao i vi.","type":"string","required":false},"date_format":{"title":"","description":"Oblik datuma za sve niske datuma.","type":"string","required":false},"time_format":{"title":"","description":"Oblik vremena za sve niske vremena.","type":"string","required":false},"start_of_week":{"title":"","description":"Broj dana sedmice kada bi sedmica trebalo da po\u010dne.","type":"integer","required":false},"language":{"title":"","description":"Vordpresov kod lokalizacije.","type":"string","required":false},"use_smilies":{"title":"","description":"Pretvorite emotikone kao :-) i :-P u sli\u010dice pri prikazu.","type":"boolean","required":false},"default_category":{"title":"","description":"Podrazumevana kategorija \u010dlanka.","type":"integer","required":false},"default_post_format":{"title":"","description":"Podrazumevani oblik \u010dlanka.","type":"string","required":false},"posts_per_page":{"title":"Najve\u0107i broj \u010dlanaka po stranici","description":"Stranice bloga prikazuju najvi\u0161e.","type":"integer","required":false},"show_on_front":{"title":"Prika\u017ei na prednjoj strani","description":"\u0160ta prikazati na naslovnoj strani","type":"string","required":false},"page_on_front":{"title":"Stranica na prednjoj strani","description":"ID stranice koja treba da bude prikazana na naslovnoj strani","type":"integer","required":false},"page_for_posts":{"title":"","description":"ID stranice koja treba da prikazuje najnovije \u010dlanke","type":"integer","required":false},"default_ping_status":{"title":"","description":"Dozvoli obave\u0161tavanje putem veza sa drugih blogova (povratni pingovi i povratne veze) na novim \u010dlancima.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Dozvoli komentare na novim \u010dlancima","description":"Dozvoli ljudima predavanje komentara na novim \u010dlancima.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logotip","description":"Logotip veb mesta.","type":"integer","required":false},"site_icon":{"title":"Ikonica","description":"Ikonica sajta","type":"integer","required":false},"elementor_one_welcome_screen_completed":{"title":"","description":"Elementor One Welcome Screen Completed","type":"boolean","required":false},"elementor_one_dismiss_connect_alert":{"title":"","description":"Elementor One Dismiss Connect Alert","type":"boolean","required":false},"elementor_one_editor_update_notification_dismissed":{"title":"","description":"Elementor One Dismiss Editor Update Notification","type":"boolean","required":false},"ea11y_widget_menu_settings":{"title":"","description":"","type":"object","additionalProperties":true,"required":false},"ea11y_widget_icon_settings":{"title":"","description":"","type":"object","additionalProperties":true,"required":false},"ea11y_skip_to_content_settings":{"title":"","description":"","type":"object","additionalProperties":true,"required":false},"ea11y_widget_activation_settings":{"title":"","description":"","type":"object","additionalProperties":true,"required":false},"ea11y_plan_data":{"title":"","description":"","type":"object","additionalProperties":true,"required":false},"ea11y_accessibility_statement_data":{"title":"","description":"","type":"object","additionalProperties":true,"required":false},"ea11y_close_post_connect_modal":{"title":"","description":"","type":"boolean","required":false},"ea11y_hide_minimum_active_options_alert":{"title":"","description":"","type":"boolean","required":false},"ea11y_analytics_enabled":{"title":"","description":"","type":"boolean","required":false},"ea11y_show_accessibility_generated_page_infotip":{"title":"","description":"","type":"boolean","required":false},"ea11y_unfiltered_files_upload":{"title":"","description":"","type":"boolean","required":false},"ea11y_close_onboarding_modal":{"title":"","description":"","type":"boolean","required":false},"ea11y_close_get_started_modal":{"title":"","description":"","type":"boolean","required":false},"ea11y_dismissed_quota_notices":{"title":"","description":"","type":"array","items":{"type":"string"},"required":false},"ea11y_review_data":{"title":"","description":"","type":"object","additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ograni\u010dite skup rezultata na \u010dlanke kojima je dodeljen jedno ili vi\u0161e stanja.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Stil teme. Ovo jedinstveno identifikuje temu.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"status":{"description":"Ograni\u010dava rezultate na dodatke sa datim stanjem.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Podlo\u017eak u WordPress.org direktorijumu dodataka.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Stanje uklju\u010denosti dodataka.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Stanje uklju\u010denosti dodataka.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator registrovane bo\u010dne trake","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Ugne\u017e\u0111eni vid\u017eeti.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator tipa vid\u017eeta.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifikator tipa vid\u017eeta.","type":"string","required":true},"instance":{"description":"Trenutna pode\u0161avanja vid\u017eeta.","type":"object","required":false},"form_data":{"description":"Serijalizovani podaci o obrascu vid\u017eeta za kodiranje u pode\u0161avanja instance.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifikator tipa vid\u017eeta.","type":"string","required":true},"instance":{"description":"Trenutna pode\u0161avanja vid\u017eeta.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Bo\u010dna traka za povratak vid\u017eeta.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator vid\u017eeta.","type":"string","required":false},"id_base":{"description":"Vrsta vid\u017eeta. Odgovara identifikatoru u krajnjoj ta\u010dki za tipove vid\u017eeta.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Bo\u010dna traka kojoj pripada vid\u017eet.","type":"string","required":true},"instance":{"description":"Pode\u0161avanja instance vid\u017eeta, ako je podr\u017eano.","type":"object","properties":{"encoded":{"description":"Base64 enkodirano prikazivanje pode\u0161avanja instance.","type":"string","context":["edit"]},"hash":{"description":"Kriptografska he\u0161 vrednost pode\u0161avanja instance.","type":"string","context":["edit"]},"raw":{"description":"Nekodirani primer pode\u0161avanja, ako je podr\u017eano.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodirani podaci obrasca iz administrativnog obrasca vid\u017eeta. Koristi se za a\u017euriranje vid\u017eeta koji ne podr\u017eava instancu. Samo za pisanje.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Jedinstveni identifikator vid\u017eeta.","type":"string","required":false},"id_base":{"description":"Vrsta vid\u017eeta. Odgovara identifikatoru u krajnjoj ta\u010dki za tipove vid\u017eeta.","type":"string","required":false},"sidebar":{"description":"Bo\u010dna traka kojoj pripada vid\u017eet.","type":"string","required":false},"instance":{"description":"Pode\u0161avanja instance vid\u017eeta, ako je podr\u017eano.","type":"object","properties":{"encoded":{"description":"Base64 enkodirano prikazivanje pode\u0161avanja instance.","type":"string","context":["edit"]},"hash":{"description":"Kriptografska he\u0161 vrednost pode\u0161avanja instance.","type":"string","context":["edit"]},"raw":{"description":"Nekodirani primer pode\u0161avanja, ako je podr\u017eano.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodirani podaci obrasca iz administrativnog obrasca vid\u017eeta. Koristi se za a\u017euriranje vid\u017eeta koji ne podr\u017eava instancu. Samo za pisanje.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Da li da prinudno uklonim vid\u017eet ili da ga premestim na neaktivnu bo\u010dnu traku.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ograni\u010dite rezultate na one blokove koji odgovaraju izrazu pretrage.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","minLength":1,"required":false},"category":{"description":"Ograni\u010di rezultate na one koji odgovaraju identifikacionom broju kategorije.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ograni\u010di rezultate na one koji odgovaraju identifikacionom klju\u010du.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ograni\u010di rezultate na one koji se podudaraju sa mustrom (podlo\u017eakom).","type":"array","required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiraj kolekciju po atributu \u010dlanka.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL za obradu.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Alfanumeri\u010dki identifikator za lokaciju izbornika.","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Unique identifier for the ability category.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Input parameters for the ability execution.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limit results to abilities in specific ability category.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Unique identifier for the ability.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"slug":{"description":"Jedinstveni podlo\u017eak koji identifikuje \u0161ablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifikator teme za \u0161ablon.","type":"string","required":false},"type":{"description":"Vrsta \u0161ablona.","type":"string","required":false},"content":{"description":"Sadr\u017eaj \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Sadr\u017eaj za \u0161ablon, kakav je u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika bloka sadr\u017eaja koji koristi \u0161ablon.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Naslov \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Naslov za \u0161ablon, kakav u bazi podataka.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML naslov za \u0161ablon, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis \u0161ablona.","type":"string","required":false},"status":{"description":"Stanje \u0161ablona.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID za autora \u0161ablona.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"id":{"description":"ID automatskog snimanja.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Trenutna stranica zbirke.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Najve\u0107i broj stavki koje se vra\u0107aju u skupu rezultata.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ograni\u010dite rezultate na one koji odgovaraju niski.","type":"string","required":false},"exclude":{"description":"Pobrinite se da skup rezultata isklju\u010duje posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ograni\u010dite skup rezultata na posebne ID-jeve.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Odstupite skup rezultata za poseban broj stavki.","type":"integer","required":false},"order":{"description":"Pore\u0111ajte redosled kao rastu\u0107i ili opadaju\u0107i.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Pore\u0111ajte zbirku po osobini predmeta.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identifikator \u0161ablona","type":"string","required":false},"id":{"description":"Jedinstveni identifikator revizije.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Neophodno je da bude true po\u0161to revizije ne podr\u017eavaju preme\u0161tanje na otpad.","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Ograni\u010di na odre\u0111eni identifikator \u010dlanka.","type":"integer","required":false},"area":{"description":"Ograni\u010di na odre\u0111eni prostor dela \u0161ablona.","type":"string","required":false},"post_type":{"description":"Vrsta \u010dlanka za koju \u0107ete dobiti \u0161ablone.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Jedinstveni podlo\u017eak koji identifikuje \u0161ablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifikator teme za \u0161ablon.","type":"string","required":false},"type":{"description":"Vrsta \u0161ablona.","type":"string","required":false},"content":{"default":"","description":"Sadr\u017eaj \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Sadr\u017eaj za \u0161ablon, kakav je u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika bloka sadr\u017eaja koji koristi \u0161ablon.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Naslov \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Naslov za \u0161ablon, kakav u bazi podataka.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML naslov za \u0161ablon, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Opis \u0161ablona.","type":"string","required":false},"status":{"default":"publish","description":"Stanje \u0161ablona.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID za autora \u0161ablona.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Podlo\u017eak \u0161ablona za dobijanje alternative","type":"string","required":true},"is_custom":{"description":"Ozna\u010dava da li je \u0161ablon prilago\u0111en ili deo hijerarhije \u0161ablona","type":"boolean","required":false},"template_prefix":{"description":"Prefiks \u0161ablona za napravljeni \u0161ablon. Ovo se koristi za izdvajanje glavnog tipa \u0161ablona, na primer, u `taxonomy-books` izdvaja `taxonomy`.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"slug":{"description":"Jedinstveni podlo\u017eak koji identifikuje \u0161ablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifikator teme za \u0161ablon.","type":"string","required":false},"type":{"description":"Vrsta \u0161ablona.","type":"string","required":false},"content":{"description":"Sadr\u017eaj \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Sadr\u017eaj za \u0161ablon, kakav je u bazi podataka.","type":"string","context":["view","edit"]},"block_version":{"description":"Izdanje oblika bloka sadr\u017eaja koji koristi \u0161ablon.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Naslov \u0161ablona.","type":["object","string"],"properties":{"raw":{"description":"Naslov za \u0161ablon, kakav u bazi podataka.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML naslov za \u0161ablon, pretvoren za prikaz.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis \u0161ablona.","type":"string","required":false},"status":{"description":"Stanje \u0161ablona.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID za autora \u0161ablona.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Da li da se presko\u010di otpad i prisili brisanje.","required":false}}}]},"\/wp\/v2\/registered-templates":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Ograni\u010di na odre\u0111eni identifikator \u010dlanka.","type":"integer","required":false},"area":{"description":"Ograni\u010di na odre\u0111eni prostor dela \u0161ablona.","type":"string","required":false},"post_type":{"description":"Vrsta \u010dlanka za koju \u0107ete dobiti \u0161ablone.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/registered-templates"}]}},"\/wp\/v2\/registered-templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifikator \u0161ablona","type":"string","required":false},"context":{"description":"Obim pod kojim je zahtev napravljen; odre\u0111uje polja koja se nalaze u odgovoru.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Entity kind.","type":"string","required":true},"name":{"description":"Entity name.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":20117,"site_icon":8423,"site_icon_url":"https:\/\/magazinmehatronika.com\/wp-content\/uploads\/2019\/12\/cropped-mehatronikaW.webp","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/media\/20117"},{"embeddable":true,"type":"site_icon","href":"https:\/\/magazinmehatronika.com\/wp-json\/wp\/v2\/media\/8423"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
