Home»News»New Modulostar® fuse holder simple, compact, robust by mersen
News
Aleksandar DakićBy Aleksandar Dakić19/07/2019Updated:01/09/20233 Mins Read
image description
Saint Bonnet de Mure, 14 september 2018 – Mersen (Euronext FR0000039620 – MRN) is a global expert in electrical protection and control for electrical power systems. Mersen designs and markets a comprehensive protection offer for selective power applications in building, industry, and energy.
Mersen is launching a brand-new Modulostar® fuse-disconnector for applications with power cylindrical low voltage fuses. Emmanuelle Delcambre, IEC Low Voltage Product Manager for Mersen introduces us the key features and benefits of the product:
“Modulostar® is simple. Simple because it is modular. Models are available from 1 to 4 poles for cylindrical fuses with 690VAC/DC voltage rating as per IEC and for some part numbers up to 1000VAC/DC rating as per both IEC and UL. Simple because Modulostar® is snapped easily on DIN rail via a slight push. Simple because changing a fuse is easier thanks to the fuse carrier’s wider opening angle, the widest opening angle ever seen in the market. Access to the fuse is now fast. Simple blown fuse indication for models concerned. The indicator is located on the front of the fuse carrier. Two LEDs fulfill this function for alternating and direct currents. Simple because new fuse holders can be straight padlocked through a handy eyelet when the fuse carrier is in the open position.
Modulostar® is compact. The space-saving new Modulostar® fuse holder is almost 10mm shorter than the previous line. The new design is made through modern and tightened lines, leading to a more compact shape. Compactness drives to increased energy efficiency, with this new design Modulostar® features lower power losses.
Modulostar® is robust. The molded-plastic case of the holder is robust and rigid enough for use in the most demanding environments like process industries and transportation. This new fuse holder features high-grade plastic materials. They are classified UL V0 to V2 and R22HL2, complying with the new EN45545 regulation for rail transportation. The fuse holder can be opened and closed quickly with clear sound confirmation. The new Modulostar® withstands high tightening torques for cabling. 2N.m is the recommended torque, but the product has been tested up to 50% higher (3N.m). Unlocking the holder from DIN rail after mounting is very easy, simply use a screwdriver to actuate the rail lock built into the molded-plastic envelope.”
About Mersen
Global Expert in electrical specialties and graphite-based materials, Mersen designs innovative solutions to address its clients’ specific needs to enable them to optimize their manufacturing process in sectors such as energy, transportation, electronics, chemical, pharmaceutical and process industries.
Mersen works with the customer to integrate our products for electrical power into the customer’s application, to make it safer and more reliable.
Electrical Protection & Control
    • Overcurrent Protection
            ▪ IEC Fuses & Fusegear
            ▪ UL/CSA Fuses & Fusegear
    • Overvoltage Protection
            ▪ Lightning & Surge Protection
    • Control
            ▪ Low Voltage Switches
            ▪ Fuse Switch Disconnectors
            ▪ Metering
Solutions for Power Management
    • High-speed Fuses
    • Cooling
    • Bus bars
Mersen
Previous ArticleRaspberry Pi 4 set to drive low-cost digital transformation
Next Article Transparent filling operations thanks to data collection with zenon
28/08/2025
10/06/2025
17/05/2025
21/03/2024
21/03/2024
magazin Mehatronika and NVIDIA support Pupin’s Challenge 2023
10/02/2024
